주요 콘텐츠로 건너뛰기
Lenovo Essential G560 Back Panel Replacement
필요한 것
  1. Lenovo Essential G560 Back Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Back Panel Replacement: 2 단계, 이미지 1/2 Lenovo Essential G560 Back Panel Replacement: 2 단계, 이미지 2/2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Back Panel Replacement: 3 단계, 이미지 1/1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Back Panel Replacement, Back Panel: 4 단계, 이미지 1/1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 Back Panel Replacement: 5 단계, 이미지 1/2 Lenovo Essential G560 Back Panel Replacement: 5 단계, 이미지 2/2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 Back Panel Replacement: 6 단계, 이미지 1/1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Lawrence Downs
회원 가입일: 01/11/13
383 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 회원
CPSU-REGAN-W13S18G40
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 4,819
