주요 콘텐츠로 건너뛰기
Lenovo Essential G570 Back Panel Replacement
필요한 것
  1. Lenovo Essential G570 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn the laptop over so that the bottom side is facing up.
  2. Lenovo Essential G570 Back Panel Replacement: 2 단계, 이미지 1/1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  3. Lenovo Essential G570 Back Panel Replacement: 3 단계, 이미지 1/3 Lenovo Essential G570 Back Panel Replacement: 3 단계, 이미지 2/3 Lenovo Essential G570 Back Panel Replacement: 3 단계, 이미지 3/3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Justin Bickford
회원 가입일: 03/01/18
446 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 1,534
