주요 콘텐츠로 건너뛰기
Lenovo Flex 2-14 Hard Drive Replacement
필요한 것
  1. Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Make sure your laptop is off before you begin.
    • Flip the laptop over so the bottom is facing upwards.
    • Remove all nine 6mm Phillips #0 screws located along the edges and in the centre of the back panel.
  2. Lenovo Flex 2-14 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo Flex 2-14 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Using a prying tool, carefully lift up the keyboard.
  3. Lenovo Flex 2-14 Hard Drive Replacement: 3 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement: 3 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Take out the keyboard by disconnecting the cable.
  4. Lenovo Flex 2-14 Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo Flex 2-14 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove all four 3.5 mm Phillips screws underneath the keyboard.
  5. Lenovo Flex 2-14 Hard Drive Replacement: 5 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement: 5 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Separate the top and bottom panels of the laptop using a prying tool.
    • Slide the prying tool along the edges of the laptop until the bottom panel is completely separated.
    • Remove the back cover of the laptop once you have finished prying it open.
  6. Lenovo Flex 2-14 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the two 4 mm Phillips screws holding the hard drive adapter in place.
  7. Lenovo Flex 2-14 Hard Drive Replacement: 7 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement: 7 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Take out the adapter containing the hard drive from the laptop.
    • Remove all four 4mm Phillips screws from the adapter.
  8. Lenovo Flex 2-14 Hard Drive Replacement: 8 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement: 8 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement: 8 단계, 이미지 3/3
    • Remove the hard drive from the adapter.
    • Insert the new hard drive into the adapter.
  9. Lenovo Flex 2-14 Hard Drive Replacement: 9 단계, 이미지 1/3 Lenovo Flex 2-14 Hard Drive Replacement: 9 단계, 이미지 2/3 Lenovo Flex 2-14 Hard Drive Replacement: 9 단계, 이미지 3/3
    • Put all four 4mm Phillips screws back into the adapter with the hard drive, in order to hold it in place.
    • Put the adapter back in and reassemble the laptop.
    • Before reassembling, make sure the hard drive is securely in the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eva Beilin
회원 가입일: 05/10/20
223 평판
안내서 1개 작성함
York University, Team S1-G3, O'Regan Summer 2020 York University, Team S1-G3, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G3
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 56
전체 시간: 3,804
