주요 콘텐츠로 건너뛰기
Lenovo Flex 3-1120 Network Card Replacement
필요한 것
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: 2 단계, 이미지 1/2 Lenovo Flex 3-1120 Network Card Replacement: 2 단계, 이미지 2/2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: 3 단계, 이미지 1/1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: 4 단계, 이미지 1/1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: 5 단계, 이미지 1/1
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: 6 단계, 이미지 1/2 Lenovo Flex 3-1120 Network Card Replacement: 6 단계, 이미지 2/2
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: 7 단계, 이미지 1/1
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: 8 단계, 이미지 1/2 Lenovo Flex 3-1120 Network Card Replacement: 8 단계, 이미지 2/2
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
결론
Geoff Bentz
회원 가입일: 03/09/16
934 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G1
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 795
