주요 콘텐츠로 건너뛰기
Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
필요한 것
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 2 단계, 이미지 1/2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 2 단계, 이미지 2/2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 4 단계, 이미지 1/2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 4 단계, 이미지 2/2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 5 단계, 이미지 1/3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 5 단계, 이미지 2/3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 5 단계, 이미지 3/3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 6 단계, 이미지 1/2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 6 단계, 이미지 2/2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rie Kuraoka
회원 가입일: 01/23/20
886 평판
안내서 7개 작성하였습니다
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 회원
CPSU-PATON-S20S7G10
2 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 365
