주요 콘텐츠로 건너뛰기
Lenovo Flex 6-11IGM Display Replacement
필요한 것
  1. Lenovo Flex 6-11IGM Display Replacement, Display: 1 단계, 이미지 1/2 Lenovo Flex 6-11IGM Display Replacement, Display: 1 단계, 이미지 2/2
    • Place the laptop face-up.
    • Open the laptop.
  2. Lenovo Flex 6-11IGM Display Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening pick, begin to gently separate the display from the case, moving around the edge.
    • Using the plastic opening pick, begin to gently separate the plastic trim from the case, moving around the edge.
  3. Lenovo Flex 6-11IGM Display Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the three 2.5 mm screws that secure the display.
    • Secure a suction cup to the screen and pull it free from the upper case with light force.
    • Rest the display on the keyboard.
  4. Lenovo Flex 6-11IGM Display Replacement: 4 단계, 이미지 1/2 Lenovo Flex 6-11IGM Display Replacement: 4 단계, 이미지 2/2
    • Disengage the cable located at the bottom of the display.
    • Slide a plastic opening pick under the brown bar, lifting the bar up, and disengage the wire with your fingers.
    • Disengage the cable at the bottom left of the display with your fingers.
    • Disengage the cable at the top center of the display using your fingers and remove the cable from the display housing.
  5. Lenovo Flex 6-11IGM Display Replacement: 5 단계, 이미지 1/1
    • Remove the display.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Edens
회원 가입일: 09/16/20
235 평판
안내서 2개 작성하였습니다
댓글 한 개
Can you replace the digitizer separately? Or do you have to get the digitizer and lcd combo for replacement? Is it worth it at $130 for the replacement? Laptop is only a couple years old…
Tyson Strickland - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 10
전체 시간: 615
