주요 콘텐츠로 건너뛰기
Lenovo Flex 6-11IGM Heat Sink Replacement
필요한 것
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: 2 단계, 이미지 1/2 Lenovo Flex 6-11IGM Heat Sink Replacement: 2 단계, 이미지 2/2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: 4 단계, 이미지 1/2 Lenovo Flex 6-11IGM Heat Sink Replacement: 4 단계, 이미지 2/2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: 5 단계, 이미지 1/2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: 6 단계, 이미지 1/3 Lenovo Flex 6-11IGM Heat Sink Replacement: 6 단계, 이미지 2/3 Lenovo Flex 6-11IGM Heat Sink Replacement: 6 단계, 이미지 3/3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: 7 단계, 이미지 1/1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: 8 단계, 이미지 1/3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: 8 단계, 이미지 2/3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: 8 단계, 이미지 3/3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: 9 단계, 이미지 1/2 Lenovo Flex 6-11IGM Heat Sink Replacement: 9 단계, 이미지 2/2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
결론
Rie Kuraoka
회원 가입일: 01/23/20
886 평판
안내서 7개 작성하였습니다
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 회원
CPSU-PATON-S20S7G10
2 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 288
