주요 콘텐츠로 건너뛰기
Lenovo Flex 6-11IGM Speaker Unit Replacement
필요한 것
  1. Lenovo Flex 6-11IGM Speaker Unit Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Speaker Unit Replacement: 2 단계, 이미지 1/2 Lenovo Flex 6-11IGM Speaker Unit Replacement: 2 단계, 이미지 2/2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Speaker Unit Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Speaker Unit Replacement: 4 단계, 이미지 1/2 Lenovo Flex 6-11IGM Speaker Unit Replacement: 4 단계, 이미지 2/2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Speaker Unit Replacement, Speaker Unit: 5 단계, 이미지 1/3 Lenovo Flex 6-11IGM Speaker Unit Replacement, Speaker Unit: 5 단계, 이미지 2/3 Lenovo Flex 6-11IGM Speaker Unit Replacement, Speaker Unit: 5 단계, 이미지 3/3
    • For the right speaker, disconnect the wire using the iFixit opening tool.
    • Pull the speaker out.
  6. Lenovo Flex 6-11IGM Speaker Unit Replacement: 6 단계, 이미지 1/2 Lenovo Flex 6-11IGM Speaker Unit Replacement: 6 단계, 이미지 2/2
    • For the speaker on the left, disconnect the wire using the iFixit opening tool.
결론
Juan Palominos JR
회원 가입일: 01/23/20
217 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G4, White Winter 2020 Cal Poly, Team S2-G4, White Winter 2020 회원
CPSU-WHITE-W20S2G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 8
전체 시간: 135
