소개
Replacing the keyboard is a quick and easy task. Removing the keyboard only took three tools: A JIS #1 screwdriver, plastic opening tool, and tweezers. Before you start make sure you remove the battery and unplug the device.
필요한 것
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
다른 2명이 해당 안내서를 완성하였습니다.
