소개
This replacement is moderately difficult and should only take fifteen to twenty minuets. You will need a JIS #0 screwdriver, tweezers, and a plastic opening tool. Before you start on the speakers make sure you take out the battery.
필요한 것
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
Next, use the tweezers to pull the connector out away from the screen.
다른 한 분이 해당 안내서를 완성하였습니다.
