소개
A computer has RAM (random access memory) as a place to hold the information it is computing. This is important because it takes longer to pull the information from the hard drive. Upgrading to a higher RAM capacity will increase computing speeds because it won't have to take information from the hard drive as often.
필요한 것
Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
Push the right switch (labeled 2) to the right. This will eject battery.
다른 7명이 해당 안내서를 완성하였습니다.
