주요 콘텐츠로 건너뛰기
Lenovo G50-70 Screen Replacement
필요한 것
  1. Lenovo G50-70 Screen Replacement, Screen: 1 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement, Screen: 1 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Push the switches outwards to release the battery.
    • It is important to remove the battery in order to avoid the laptop from turning on and avoiding any electrical issues.
  2. Lenovo G50-70 Screen Replacement: 2 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 2 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 2 단계, 이미지 3/3
    • Use a flat head screwdriver (or a plastic opening tool) to pop off the screen bezel/ plastic cover.
    • Once one side comes off you can use your hands to pull the rest of the plastic cover off; it shouldn't take much force to remove it from the device.
  3. Lenovo G50-70 Screen Replacement: 3 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 3 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 3 단계, 이미지 3/3
    • After removing the plastic cover, gently tilt and lift the screen, but do not remove it from the device.
  4. Lenovo G50-70 Screen Replacement: 4 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 4 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove four 3.5 mm screws at the top right and left side of the screen.
  5. Lenovo G50-70 Screen Replacement: 5 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 5 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 5 단계, 이미지 3/3
    • Using the same Phillips #00 screwdriver, remove the four 3.5 mm screws at the bottom of the screen.
  6. Lenovo G50-70 Screen Replacement: 6 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 6 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 6 단계, 이미지 3/3
    • Once the screen is loose and can be moved around, make sure to readjust the laptop gently.
    • Lay the screen flat on the keyboard in order to make it easier to find the connector.
  7. Lenovo G50-70 Screen Replacement: 7 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 7 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, peel the sticker to off of the device.
  8. Lenovo G50-70 Screen Replacement: 8 단계, 이미지 1/3 Lenovo G50-70 Screen Replacement: 8 단계, 이미지 2/3 Lenovo G50-70 Screen Replacement: 8 단계, 이미지 3/3
    • Carefully disconnect the display cable from the rest of the screen.
  9. Lenovo G50-70 Screen Replacement: 9 단계, 이미지 1/1
    • Remove the screen from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Navas
회원 가입일: 10/05/21
217 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-8, Grodsky Fall 2021 CSU Los Angeles, Team 11-8, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 61
전체 시간: 1,469
