주요 콘텐츠로 건너뛰기
Lenovo G50-80 80E5 Hard Drive Replacement
필요한 것
  1. Lenovo G50-80 80E5 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo G50-80 80E5 Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo G50-80 80E5 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Hard Drive Replacement: 3 단계, 이미지 1/3 Lenovo G50-80 80E5 Hard Drive Replacement: 3 단계, 이미지 2/3 Lenovo G50-80 80E5 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Hard Drive Replacement: 4 단계, 이미지 1/3 Lenovo G50-80 80E5 Hard Drive Replacement: 4 단계, 이미지 2/3 Lenovo G50-80 80E5 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: 5 단계, 이미지 1/2 Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: 5 단계, 이미지 2/2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo G50-80 80E5 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Rotate the laptop until you are positioned over the hard drive.
  8. Lenovo G50-80 80E5 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Use the #00 Phillips screwdriver to remove the four 5.5mm screws around the hard drive.
  9. Lenovo G50-80 80E5 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Slide the hard drive towards yourself and remove it.
결론
If you would like to reassemble your device, please follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Noah Baldwin
회원 가입일: 02/08/22
350 평판
안내서 3개 작성하였습니다
University of Kentucky, Team 1-4, Kaufmann Spring 2022 University of Kentucky, Team 1-4, Kaufmann Spring 2022 회원
UKY-KAUFMANN-S22S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 30
전체 시간: 765
