주요 콘텐츠로 건너뛰기
Lenovo G50-80 80E5 RAM Replacement
필요한 것
  1. Lenovo G50-80 80E5 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 RAM Replacement: 2 단계, 이미지 1/3 Lenovo G50-80 80E5 RAM Replacement: 2 단계, 이미지 2/3 Lenovo G50-80 80E5 RAM Replacement: 2 단계, 이미지 3/3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 RAM Replacement: 3 단계, 이미지 1/3 Lenovo G50-80 80E5 RAM Replacement: 3 단계, 이미지 2/3 Lenovo G50-80 80E5 RAM Replacement: 3 단계, 이미지 3/3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 RAM Replacement: 4 단계, 이미지 1/3 Lenovo G50-80 80E5 RAM Replacement: 4 단계, 이미지 2/3 Lenovo G50-80 80E5 RAM Replacement: 4 단계, 이미지 3/3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: 5 단계, 이미지 1/2 Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: 5 단계, 이미지 2/2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 RAM Replacement: 6 단계, 이미지 1/2 Lenovo G50-80 80E5 RAM Replacement: 6 단계, 이미지 2/2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 RAM Replacement, RAM: 7 단계, 이미지 1/2 Lenovo G50-80 80E5 RAM Replacement, RAM: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to push the two silver clips to the left and right of the RAM chip outwards.
    • The RAM will release after pushing the second clip.
  8. Lenovo G50-80 80E5 RAM Replacement: 8 단계, 이미지 1/1
    • Use your fingers to carefully remove the RAM chip by sliding it out at a ~45° angle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Noah Baldwin
회원 가입일: 02/08/22
350 평판
안내서 3개 작성하였습니다
University of Kentucky, Team 1-4, Kaufmann Spring 2022 University of Kentucky, Team 1-4, Kaufmann Spring 2022 회원
UKY-KAUFMANN-S22S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 35
전체 시간: 1,257
