주요 콘텐츠로 건너뛰기
Lenovo G50-80 80E5 Removing top panel Replacement
필요한 것
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: 1 단계, 이미지 1/1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: 2 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement: 2 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement: 2 단계, 이미지 3/3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: 3 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement: 3 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement: 3 단계, 이미지 3/3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: 4 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement: 4 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement: 4 단계, 이미지 3/3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: 5 단계, 이미지 1/2 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: 5 단계, 이미지 2/2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: 6 단계, 이미지 1/2 Lenovo G50-80 80E5 Removing top panel Replacement: 6 단계, 이미지 2/2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 7 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 7 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: 7 단계, 이미지 3/3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: 8 단계, 이미지 1/1
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: 9 단계, 이미지 1/2 Lenovo G50-80 80E5 Removing top panel Replacement: 9 단계, 이미지 2/2
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: 10 단계, 이미지 1/1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: 11 단계, 이미지 1/1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: 12 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: 13 단계, 이미지 1/2 Lenovo G50-80 80E5 Removing top panel Replacement: 13 단계, 이미지 2/2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: 14 단계, 이미지 1/1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: 15 단계, 이미지 1/1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: 16 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: 17 단계, 이미지 1/1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: 18 단계, 이미지 1/1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: 19 단계, 이미지 1/1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: 20 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement: 20 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement: 20 단계, 이미지 3/3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: 21 단계, 이미지 1/1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: 22 단계, 이미지 1/2 Lenovo G50-80 80E5 Removing top panel Replacement: 22 단계, 이미지 2/2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: 23 단계, 이미지 1/1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: 24 단계, 이미지 1/1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: 25 단계, 이미지 1/3 Lenovo G50-80 80E5 Removing top panel Replacement: 25 단계, 이미지 2/3 Lenovo G50-80 80E5 Removing top panel Replacement: 25 단계, 이미지 3/3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: 26 단계, 이미지 1/1
    • Top covered removed
결론
다른 12명이 해당 안내서를 완성하였습니다.
Victor
회원 가입일: 10/17/17
1,309 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 54
전체 시간: 7,467
