주요 콘텐츠로 건너뛰기
Lenovo G575 Fan Replacement
필요한 것
  1. Lenovo G575 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
결론
Samson Wong
회원 가입일: 09/21/20
103 평판
안내서 1개 작성함
York University, Team S1-G75, Woodhouse Fall 2020 York University, Team S1-G75, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G75
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 870
