주요 콘텐츠로 건너뛰기
Lenovo G580 Battery Replacement
필요한 것
  1. Lenovo G580 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your laptop is oriented backside facing upward as seen in the image.
    • Locate the battery lock switch.
  2. Lenovo G580 Battery Replacement: 2 단계, 이미지 1/2 Lenovo G580 Battery Replacement: 2 단계, 이미지 2/2
    • Unlock the battery by moving the switch to the right.
    • The switch is unlocked when the RED of the switch is present.
  3. Lenovo G580 Battery Replacement: 3 단계, 이미지 1/2 Lenovo G580 Battery Replacement: 3 단계, 이미지 2/2
    • Hold the release switch down.
    • At the same time, push the battery upwards to remove the battery.
    • Pulling on the battery while the battery is locked will damage the laptop. Ensure the lock is properly disengaged.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle McNeil
회원 가입일: 10/28/18
337 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 1,777
