주요 콘텐츠로 건너뛰기
Lenovo G580 Keyboard Replacement
필요한 것
  1. Lenovo G580 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: 3 단계, 이미지 1/1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: 5 단계, 이미지 1/1
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: 6 단계, 이미지 1/2 Lenovo G580 Keyboard Replacement: 6 단계, 이미지 2/2
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: 7 단계, 이미지 1/1
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kyle McNeil
회원 가입일: 10/28/18
337 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 28
전체 시간: 4,164
