주요 콘텐츠로 건너뛰기
Lenovo G70-70 Fan Replacement
필요한 것
  1. Lenovo G70-70 Fan Replacement, Battery: 1 단계, 이미지 1/2 Lenovo G70-70 Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Fan Replacement: 2 단계, 이미지 1/2 Lenovo G70-70 Fan Replacement: 2 단계, 이미지 2/2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Fan Replacement: 3 단계, 이미지 1/3 Lenovo G70-70 Fan Replacement: 3 단계, 이미지 2/3 Lenovo G70-70 Fan Replacement: 3 단계, 이미지 3/3
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Fan Replacement, Fan: 4 단계, 이미지 1/3 Lenovo G70-70 Fan Replacement, Fan: 4 단계, 이미지 2/3 Lenovo G70-70 Fan Replacement, Fan: 4 단계, 이미지 3/3
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Fan Replacement: 5 단계, 이미지 1/3 Lenovo G70-70 Fan Replacement: 5 단계, 이미지 2/3 Lenovo G70-70 Fan Replacement: 5 단계, 이미지 3/3
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.5 mm screws from the fan using a Phillips #0 screwdriver.
    • The label M2X6 will be located next to each screw.
  6. Lenovo G70-70 Fan Replacement: 6 단계, 이미지 1/3 Lenovo G70-70 Fan Replacement: 6 단계, 이미지 2/3 Lenovo G70-70 Fan Replacement: 6 단계, 이미지 3/3
    • Pinch both sides of the white connector and pull the cord from the socket.
    • Remove the fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Crews
회원 가입일: 09/15/22
815 평판
안내서 5개 작성하였습니다
University of Memphis, Team 3-3, Lane Fall 2022 University of Memphis, Team 3-3, Lane Fall 2022 회원
UM-LANE-F22S3G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 128
