소개
If your Lenovo G70-70 laptop frequently turns off while you are working on it and the bottom of the laptop feels hot, use this guide to replace the fan. The fan turns on to prevent the inside of the computer from overheating. A faulty fan will not turn on to cool the overheating motherboards. Before using this guide, inspect the vents above the fan for debris that may prevent airflow to the internal section of the laptop. Typically, a small buildup of dust can be removed with a small brush or a dust blower. This repair is necessary to keep the inside of your laptop cool so it can run properly. Before attempting to replace the fan, ensure the battery is removed to prevent getting shocked.
필요한 것
Orient the laptop so the bottom side is facing you.
To unlock the battery, place your thumb over the left switch and slide it to the left.
다른 한 분이 해당 안내서를 완성하였습니다.
