주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo G70-70 Keyboard Replacement
필요한 것
  1. Lenovo G70-70 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo G70-70 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo G70-70 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Lenovo G70-70 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Lenovo G70-70 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Lenovo G70-70 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Lenovo G70-70 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Lenovo G70-70 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Lenovo G70-70 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.2 mm Phillips #0 screws.
    • The label M2X6 is written next to each screw that keeps the keyboard secure.
  6. Lenovo G70-70 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo G70-70 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo G70-70 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the laptop over so the top side is facing you and open the laptop.
    • Carefully pry open any corner of the keyboard with the metal spudger.
    • Slide the metal spudger around the perimeter of the keyboard until you can lift it.
    • You will hear loud popping noises as the keyboard separates from the laptop.
  7. Lenovo G70-70 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Lenovo G70-70 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the keyboard.
    • Use your finger or the opening tool to pull the locking flap toward yourself.
  8. Lenovo G70-70 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Lenovo G70-70 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the silver ribbon cable away from you to disconnect the keyboard.
    • Remove the keyboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joseph Crews
회원 가입일: 09/15/22
842 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 46
전체 시간: 478
