소개
If the keyboard on your Lenovo G70-70 laptop does not respond to any inputs or some keys are stuck, use this guide to replace the keyboard. The keyboard accepts inputs you type in that will appear on the screen. A faulty keyboard will not accept any inputs, resulting in not seeing them on the screen. Before using this guide, inspect the area underneath the keys for debris that may prevent them from being pressed or cause them to get stuck in the down position. Any debris underneath the keys can be removed by wiping until the area is clean. This repair is necessary so your laptop can properly understand any inputs you type into the keyboard. Before attempting to replace the keyboard, ensure you have removed the battery to prevent getting shocked.
필요한 것
Orient the laptop so the bottom side is facing you.
To unlock the battery, place your thumb over the left switch and slide it to the left.
Turn your laptop so the bottom side is facing you.
Remove two 7.3 mm Phillips #0 screws.
Slide the back cover towards yourself.
다른 2명이 해당 안내서를 완성하였습니다.
