주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo G70-70 Screen Replacement
필요한 것
  1. Lenovo G70-70 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo G70-70 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Screen Replacement: 2 단계, 이미지 2개 중 1개 Lenovo G70-70 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Screen Replacement: 3 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement: 3 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Screen Replacement, Screen: 4 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement, Screen: 4 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement, Screen: 4 단계, 이미지 3개 중 3개
    • Pry open the plastic casing surrounding the screen with the opening tool.
    • You will hear loud popping noises as you separate the plastic casing from the screen.
    • Pull the plastic casing toward yourself and separate it from the screen.
  5. Lenovo G70-70 Screen Replacement: 5 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement: 5 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the plastic casing upward and toward yourself to completely remove it from the laptop.
    • Remove eight 4.5 mm screws from the front of the metal casing with a Phillips #0 screwdriver.
    • There are three screws on the bottom left and right sides of the screen. There is one screw on the top left and right side of the screen.
  6. Lenovo G70-70 Screen Replacement: 6 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement: 6 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Lower the screen to separate it from the plastic casing behind it.
    • Remove four 3.2 mm screws from the sides of the metal casing with a Phillips #0 screwdriver.
    • There are two screws on each side of the metal casing.
  7. Lenovo G70-70 Screen Replacement: 7 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement: 7 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Lay the screen down on the keyboard to gain access to the cable on the back of the screen.
    • Use your hands or a sturdy object to prop the rear plastic casing up to avoid damaging the cable.
    • Pull the plastic off of the top of the cable.
  8. Lenovo G70-70 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully pull the golden part of the cable towards yourself to remove it from the bottom part of the screen.
  9. Lenovo G70-70 Screen Replacement: 9 단계, 이미지 3개 중 1개 Lenovo G70-70 Screen Replacement: 9 단계, 이미지 3개 중 2개 Lenovo G70-70 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Detach the cable by pulling it away from yourself.
    • Once the cable is detached from the screen you will be able to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joseph Crews
회원 가입일: 09/15/22
842 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 40
전체 시간: 453
