주요 콘텐츠로 건너뛰기
Lenovo G70-80 Battery Replacement
  1. Lenovo G70-80 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Battery Replacement: 2 단계, 이미지 1/2 Lenovo G70-80 Battery Replacement: 2 단계, 이미지 2/2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Battery Replacement: 3 단계, 이미지 1/2 Lenovo G70-80 Battery Replacement: 3 단계, 이미지 2/2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Battery Replacement: 4 단계, 이미지 1/2 Lenovo G70-80 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alexis Buford
회원 가입일: 02/28/17
665 평판
안내서 5개 작성하였습니다
댓글 한 개
Very precise instruction, managed to not &&^& it up. Have a nice day good person!! :)
BodoGamer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 1,584
