주요 콘텐츠로 건너뛰기
Lenovo G70-80 CD Drive Replacement
필요한 것
  1. Lenovo G70-80 CD Drive Replacement, CD Drive: 1 단계, 이미지 1/3 Lenovo G70-80 CD Drive Replacement, CD Drive: 1 단계, 이미지 2/3 Lenovo G70-80 CD Drive Replacement, CD Drive: 1 단계, 이미지 3/3
    • Locate a Phillips head screwdriver. Use the screwdriver to remove the 2 screws found on the backside of the Lenovo G70-80. Once both of these screws are removed you will be able to remove the back of the laptop.
  2. Lenovo G70-80 CD Drive Replacement: 2 단계, 이미지 1/1
    • Next, you will need to locate the CD drive. If you orient the laptop with the hinge facing you, the CD drive will be in the bottom right corner near the battery.
  3. Lenovo G70-80 CD Drive Replacement: 3 단계, 이미지 1/1
    • Remove the screw to the left of the CD Drive.
  4. Lenovo G70-80 CD Drive Replacement: 4 단계, 이미지 1/1
    • Once all of the hardware in the previous steps is removed, you will be able to pull the CD drive directly out of the laptop.
결론
Reassembly should be equally as easy as the disassembly. Follow the directions step by step in reverse order to reassemble the Lenovo G70-80 with your new CD drive.
다른 한 분이 해당 안내서를 완성하였습니다.
Alexis Buford
회원 가입일: 02/28/17
665 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,013
