주요 콘텐츠로 건너뛰기
Lenovo G70-80 Screen Replacement
필요한 것
  1. Lenovo G70-80 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Screen Replacement: 2 단계, 이미지 1/2 Lenovo G70-80 Screen Replacement: 2 단계, 이미지 2/2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Screen Replacement: 3 단계, 이미지 1/2 Lenovo G70-80 Screen Replacement: 3 단계, 이미지 2/2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Screen Replacement: 4 단계, 이미지 1/2 Lenovo G70-80 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the battery.
  5. Lenovo G70-80 Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Open the laptop to face the screen.
  6. Lenovo G70-80 Screen Replacement: 6 단계, 이미지 1/3 Lenovo G70-80 Screen Replacement: 6 단계, 이미지 2/3 Lenovo G70-80 Screen Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
    • The bezel is the plastic frame around the laptop screen.
  7. Lenovo G70-80 Screen Replacement: 7 단계, 이미지 1/2 Lenovo G70-80 Screen Replacement: 7 단계, 이미지 2/2
    • After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
    • If you are having trouble removing the bezel from the LCD panel, pull both sides of the bezel towards you with your hands.
  8. Lenovo G70-80 Screen Replacement: 8 단계, 이미지 1/3 Lenovo G70-80 Screen Replacement: 8 단계, 이미지 2/3 Lenovo G70-80 Screen Replacement: 8 단계, 이미지 3/3
    • Use a screwdriver to remove the screws that secure the LCD panel to the computer.
    • Once the bezel is removed, you will see eight screws around the screen that secure the LCD panel to the computer.
  9. Lenovo G70-80 Screen Replacement: 9 단계, 이미지 1/1
    • Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
  10. Lenovo G70-80 Screen Replacement: 10 단계, 이미지 1/1
    • Disconnect the LCD panel from the computer by peeling the connector off.
  11. Lenovo G70-80 Screen Replacement: 11 단계, 이미지 1/2 Lenovo G70-80 Screen Replacement: 11 단계, 이미지 2/2
    • With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
    • There is one screw on each corner that connects to the mounting arms.
  12. Lenovo G70-80 Screen Replacement: 12 단계, 이미지 1/1
    • Remove the LCD panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexis Buford
회원 가입일: 02/28/17
665 평판
안내서 5개 작성하였습니다
댓글 한 개
how do you repair a whitescreen effect for a lenovo110 ideapad
sidney ifedha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,695
