소개
This guide will provide step-by-step instruction on how to detach the back panel and how to remove the fan and heat-sink from your motherboard.
The guide will also provide instructions on how to remove the battery and HDD to gain better access to the fan and heat-sink.
필요한 것
Flip the device so the rear case is facing upward.
With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
With the Phillips screw driver using the number one head. Carefully unscrew the the M2-6mm wire fastener, so the wires shown in the picture can be released from the rear casing.
