주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Horizon 2s HDD Replacement
필요한 것
  1. Lenovo Horizon 2s HDD Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Lenovo Horizon 2s HDD Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Lenovo Horizon 2s HDD Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s HDD Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Horizon 2s HDD Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s HDD Replacement: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s HDD Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s HDD Replacement: 5 단계, 이미지 3개 중 1개 Lenovo Horizon 2s HDD Replacement: 5 단계, 이미지 3개 중 2개 Lenovo Horizon 2s HDD Replacement: 5 단계, 이미지 3개 중 3개
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s HDD Replacement, HDD: 6 단계, 이미지 2개 중 1개 Lenovo Horizon 2s HDD Replacement, HDD: 6 단계, 이미지 2개 중 2개
    • Using your Philips head screw driver with the number 1 head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  7. Lenovo Horizon 2s HDD Replacement: 7 단계, 이미지 1개 중 1개
    • Now carefully lift the hard-drive that is still attached to the boot from the rear casing.
  8. Lenovo Horizon 2s HDD Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Horizon 2s HDD Replacement: 8 단계, 이미지 2개 중 2개
    • Now that the hard-drive is detached from the rear casing you will still have to detach the hard-drive from its boot. Again using the Philips screwdriver with the number one head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  9. Lenovo Horizon 2s HDD Replacement: 9 단계, 이미지 1개 중 1개
    • Now that the screws are detached. You can now carefully lift the hard-drive from the metal boot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zak Kazakos
회원 가입일: 09/25/17
320 평판
안내서 3개를 작성함
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017 회원
USFT-CANNON-F17S3G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 38
전체 시간: 5,724
