주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Horizon 2s Speaker Replacement
필요한 것
  1. Lenovo Horizon 2s Speaker Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Lenovo Horizon 2s Speaker Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Lenovo Horizon 2s Speaker Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Speaker Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Horizon 2s Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Speaker Replacement: 5 단계, 이미지 3개 중 1개 Lenovo Horizon 2s Speaker Replacement: 5 단계, 이미지 3개 중 2개 Lenovo Horizon 2s Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 1개 Lenovo Horizon 2s Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 2개
    • Locate the intertwined black and red wires that connect the two small, black speakers and the motherboard, as shown in the picture.
    • Disconnect this wire from the motherboard by carefully pulling it out.
  7. Lenovo Horizon 2s Speaker Replacement: 7 단계, 이미지 3개 중 1개 Lenovo Horizon 2s Speaker Replacement: 7 단계, 이미지 3개 중 2개 Lenovo Horizon 2s Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the speakers along the bottom of the device.
    • The speakers are connected by two knobs on each side. Carefully lift the speakers to detach them from the tablet.
  8. Lenovo Horizon 2s Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Finally, locate the tape that keeps the speaker wires in the grooves of the device.
    • Peel the tape off as shown and your speakers are now completely disconnected from the tablet.
결론
작성자
4다른 기여자 명과 함께
Zak Kazakos
회원 가입일: 09/25/17
320 평판
안내서 3개를 작성함
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017 회원
USFT-CANNON-F17S3G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 15
전체 시간: 452
