소개
This requires only a Phillips head screwdriver. Be aware that only 2.5" hard drives fit in this computer.
필요한 것
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 5개
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
It’s nice and easy to get there, unfortunately the board was fried lol.
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Do you have a better suggestion
