주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
필요한 것
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: 1 단계, 이미지 1/1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    No need to remove stand. Back still comes off easily.
    Marvin - 답글
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: 3 단계, 이미지 1/1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 4 단계, 이미지 1/3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 4 단계, 이미지 2/3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 4 단계, 이미지 3/3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 5 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 5 단계, 이미지 2/2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 7 단계, 이미지 1/1
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 8 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 8 단계, 이미지 2/2
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: 9 단계, 이미지 1/1
    • Lift the hard drive up to remove it from the enclosure.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Jackson Blake
회원 가입일: 01/22/18
1,119 평판
안내서 9개 작성하였습니다
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G3
4 회원들
안내서 9개 작성하였습니다
댓글 5개
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - 답글
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - 답글
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - 답글
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Donna Briggs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 71
전체 시간: 15,954
