소개
This requires using a tool to help lift up the power switch board to slide it out of the slot. Be careful and go slow when removing it. Similarly, the tabs holding the ribbon cable down are very small.
필요한 것
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
다른 한 분이 해당 안내서를 완성하였습니다.
