주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement
필요한 것
  1. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Stand Base: 1 단계, 이미지 1/1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 2 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 2 단계, 이미지 2/2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Back Cover: 3 단계, 이미지 1/1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 4 단계, 이미지 1/3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 4 단계, 이미지 2/3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 4 단계, 이미지 3/3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 5 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 5 단계, 이미지 2/2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: 6 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: 6 단계, 이미지 2/2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 7 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 7 단계, 이미지 2/2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 8 단계, 이미지 1/3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 8 단계, 이미지 2/3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: 8 단계, 이미지 3/3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Power Switch Board: 9 단계, 이미지 1/1
    • Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
  10. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 10 단계, 이미지 1/1
    • Pull the tab towards the blue and white ribbon cable to open it. Pull the cable out of the power switch board.
  11. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 11 단계, 이미지 1/2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: 11 단계, 이미지 2/2
    • Slide the power switch cable out of its slot in the direction shown, making sure to lift up the end carefully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jackson Blake
회원 가입일: 01/22/18
1,119 평판
안내서 9개 작성하였습니다
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G3
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Hello
I have a similar problem on a Lenovo AiO 510-22ISH, how can i check if the power button board is really broken down?
After sales service said that was the problem but how can i test it?
Thank You
Fred - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 1,426
