주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre K410 Heat Sink Replacement
필요한 것
  1. Lenovo IdeaCentre K410 Heat Sink Replacement, Side Panel: 1 단계, 이미지 1/1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Heat Sink Replacement: 2 단계, 이미지 1/1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Heat Sink Replacement, CPU Fan: 3 단계, 이미지 1/1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 Heat Sink Replacement: 4 단계, 이미지 1/1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 Heat Sink Replacement, Heat Sink: 5 단계, 이미지 1/1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
결론
Timothy Grebe
회원 가입일: 10/19/14
1,634 평판
안내서 9개 작성하였습니다
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G39
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 755
