주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre K410 Optical Drive Replacement
필요한 것
  1. Lenovo IdeaCentre K410 Optical Drive Replacement, Side Panel: 1 단계, 이미지 1/1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/2 Lenovo IdeaCentre K410 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/2
    • Pull up on the three tabs shown
    • Swivel the front panel so the front is open, and gently pull the cover off
  4. Lenovo IdeaCentre K410 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Push down on the button that says "push" while pulling the optical drive outward.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Timothy Grebe
회원 가입일: 10/19/14
1,634 평판
안내서 9개 작성하였습니다
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G39
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 1,817
