주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre K410 Power Supply Unit Replacement
필요한 것
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: 1 단계, 이미지 1/1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: 2 단계, 이미지 1/1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: 3 단계, 이미지 1/2 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: 3 단계, 이미지 2/2
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: 4 단계, 이미지 1/3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: 4 단계, 이미지 2/3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: 4 단계, 이미지 3/3
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: 5 단계, 이미지 1/1
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: 6 단계, 이미지 1/1
    • Remove the power supply unit by pulling away from the screw side and then out.
    C'est pas très détaillé.
    Hakou - 답글
결론
다른 9명이 해당 안내서를 완성하였습니다.
Timothy Grebe
회원 가입일: 10/19/14
1,634 평판
안내서 9개 작성하였습니다
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G39
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 35
전체 시간: 4,296
