주요 콘텐츠로 건너뛰기
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
필요한 것
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: 1 단계, 이미지 1/1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 2 단계, 이미지 1/1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: 3 단계, 이미지 1/1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: 5 단계, 이미지 1/1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Timothy Grebe
회원 가입일: 10/19/14
1,634 평판
안내서 9개 작성하였습니다
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G39
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 9
전체 시간: 1,114
