주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement
필요한 것
  1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement, USB/Headphones Jack: 1 단계, 이미지 1/1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 2 단계, 이미지 2/2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 3 단계, 이미지 1/1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 4 단계, 이미지 1/1
    • Remove the three 4mm PH00 screws.
    • Unplug the ribbon wire connected to the USB/Headphone Jack PCB by lifting the black plastic tab holding the ribbon cable down.
    • Be extra careful not to bend the ribbon cable too much as it is fragile.
  5. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: 5 단계, 이미지 2/2
    • Lift the USB/Headphone Jack PCB off of the board gently and put it to the side.
결론
Mohammed Younis
회원 가입일: 03/18/19
421 평판
안내서 3개 작성하였습니다
University of Memphis, Team S1-G3, Kim Spring 2019 University of Memphis, Team S1-G3, Kim Spring 2019 회원
UM-KIM-S19S1G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 840
