주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement
필요한 것
  1. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement, WiFi/ Bluetooth Card: 1 단계, 이미지 1/1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: 2 단계, 이미지 2/2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: 3 단계, 이미지 1/1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: 4 단계, 이미지 2/2
    • Remove the tape and unscrew the single 2mm PH00 screw.
    • Pull out the current WiFi/Bluetooth card, unplugging the two wires connected to it.
결론
Follow the guide in reverse to reassemble your device.
Congratulations on successfully completing the WiFi/Bluetooth card replacement for your Lenovo IdeaPad 100s-14IBR laptop! By following this guide, you've taken a proactive step towards improving your device's wireless capabilities, ensuring a more seamless and reliable connectivity experience.
Remember to power on your laptop and test the new card to ensure it functions correctly. If you encounter any issues, double-check your connections and revisit the steps to ensure everything is in place. Feel free to revisit this guide or seek additional assistance if needed.
다른 한 분이 해당 안내서를 완성하였습니다.
Bin Feng
회원 가입일: 03/18/19
256 평판
안내서 2개 작성하였습니다
University of Memphis, Team S1-G3, Kim Spring 2019 University of Memphis, Team S1-G3, Kim Spring 2019 회원
UM-KIM-S19S1G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 1,754
