소개
This guide details the steps to remove the Hard Disk Drive (HDD) from your Lenovo IdeaPad 110 Touch-15ACL laptop. The HDD is an additional storage component within the laptop. Many laptops are bought without an HDD and only contain a Solid State Drive (SSD) which commonly mounts to the motherboard directly. The SSD is faster than an HDD and is preferred over an HDD. Be sure to back up your information BEFORE interacting with any storage device. The HDD is mounted to a caddy-frame which additionally mounts to the computer and plugs into the ‘side’ of the motherboard. Exercise caution and do not damage any components in the device in addition to the HDD.
Before beginning this repair, you should turn off the laptop and disconnect from the power adapter.
필요한 것
Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
