주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement
필요한 것
  1. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 3 단계, 이미지 1/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 3 단계, 이미지 2/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 3 단계, 이미지 3/3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 4 단계, 이미지 3/3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Battery Replacement: 5 단계, 이미지 1/1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 6 단계, 이미지 3/3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Hard Disk Drive Replacement: 7 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: 8 단계, 이미지 2/2
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
결론
Clark Beuckman
회원 가입일: 02/22/22
529 평판
안내서 5개 작성하였습니다
Clemson, Team 2-3, Hunter Spring 2022 Clemson, Team 2-3, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 362
