주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-15IBR Battery Replacement
필요한 것
  1. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: 1 단계, 이미지 1/2 Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: 1 단계, 이미지 2/2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Remove the thirteen 9 mm Phillips #1screws.
    • Pull out the DVD drive and unscrew the final 3 wide-head screws holding the back in place.
  2. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove the back: 2 단계, 이미지 1/1
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  3. Lenovo IdeaPad 110-15IBR Battery Replacement: 3 단계, 이미지 1/1
    • Remove the two 9 mm Phillips #1 screws holding the battery.
  4. Lenovo IdeaPad 110-15IBR Battery Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad 110-15IBR Battery Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad 110-15IBR Battery Replacement: 4 단계, 이미지 3/3
    • Disconnect the battery cable connector from mother board.
    • Remove battery from device.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Saddam Alsinai
회원 가입일: 10/18/17
669 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 회원
UWT-LINER-F17S3G4
4 회원들
안내서 14개 작성하였습니다
댓글 23개
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
Clarey Ryan - 답글
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Daniel Jansen - 답글
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
charlie.bansj - 답글
I unscrew everything but to open it, it gets stuck in the middle….. i am afraid to pull hard…..
djerro - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 44
30일 전: 212
전체 시간: 46,802
