주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 1 단계, 이미지 1/2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 1 단계, 이미지 2/2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 3 단계, 이미지 2/2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove hard drive from housing.
결론
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
다른 14명이 해당 안내서를 완성하였습니다.
Saddam Alsinai
회원 가입일: 10/18/17
669 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 회원
UWT-LINER-F17S3G4
4 회원들
안내서 14개 작성하였습니다
댓글 3개
Unplug or remove battery first?
Chris Quirke - 답글
you do not need to unplug or remove the battery
Holden Phillips - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 46
전체 시간: 19,832
