소개
This guide shows how to replace the optical drive for the Lenovo IdeaPad 110-15IBR. The guide shows how to remove the back panel, remove the screws holding the drive in place, and removing the optical drive from the docking port.
필요한 것
Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
Gently pry the back off using a plastic opening tool, starting from one of the corners.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
