주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-15IBR Optical Drive Replacement
필요한 것
  1. Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/2 Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2/2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: 2 단계, 이미지 1/1
    • Using #1 Phillips screwdriver remove the 1 (9mmx6mm) screw holding the disk drive in place.
  3. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: 3 단계, 이미지 1/1
    • Pull the optical drive away from device to slide out of dock.
    • Careful not to pull the drive straight up or towards the device, otherwise damage might be done to the drive connector.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Saddam Alsinai
회원 가입일: 10/18/17
669 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 회원
UWT-LINER-F17S3G4
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
Max Härtwig - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 21
전체 시간: 3,635
