주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-15ISK Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad 110-15ISK Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Keyboard Replacement: 2 단계, 이미지 1/1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Keyboard Replacement: 3 단계, 이미지 1/1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 10/17/18
597 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G5, Rose Fall 2018 UW Tacoma, Team S1-G5, Rose Fall 2018 회원
UWT-ROSE-F18S1G5
4 회원들
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 74
전체 시간: 6,207
