소개
If the Lenovo has a blue screen appear, overheats, or locks up or freezes, then there may be a faulty motherboard. To replace the motherboard, follow the guide provided to replace it.
필요한 것
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
Pull the two connectors with blue ribbons marked with MB in the opposite direction of the connector
다른 2명이 해당 안내서를 완성하였습니다.
