주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
필요한 것
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: 1 단계, 이미지 1/1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 3 단계, 이미지 2/2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 4 단계, 이미지 3/3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 6 단계, 이미지 2/2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 8 단계, 이미지 1/1
    • Remove the hard drive from the housing mount.
결론
Cameron Mounce
회원 가입일: 09/05/23
668 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Pee Fall 2023 Gateway, Team 1-3, Pee Fall 2023 회원
GCC-PEE-F23S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 117
