주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 110-17IKB Screen Replacement
필요한 것
  1. Lenovo IdeaPad 110-17IKB Screen Replacement, Lower Case: 1 단계, 이미지 1/1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Screen Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Screen Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Screen Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad 110-17IKB Screen Replacement: 3 단계, 이미지 2/2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Screen Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad 110-17IKB Screen Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad 110-17IKB Screen Replacement: 4 단계, 이미지 3/3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: 5 단계, 이미지 1/3 Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: 5 단계, 이미지 2/3 Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Open the laptop, make sure it is facing you.
    • Using a opening pick, detach the clips around screen that is holding the bezels in place.
    • Remove all bezels.
  6. Lenovo IdeaPad 110-17IKB Screen Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad 110-17IKB Screen Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad 110-17IKB Screen Replacement: 6 단계, 이미지 3/3
    • Remove all four 3 mm screws with the a Phillips #0 screwdriver.
  7. Lenovo IdeaPad 110-17IKB Screen Replacement: 7 단계, 이미지 1/1
    • Carefully disconnect the cable connector from the connecting port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Mounce
회원 가입일: 09/05/23
668 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Pee Fall 2023 Gateway, Team 1-3, Pee Fall 2023 회원
GCC-PEE-F23S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 61
