주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 130-15AST Battery Replacement
필요한 것
  1. Lenovo IdeaPad 130-15AST Battery Replacement, DVD/CD Optical Drive: 1 단계, 이미지 1/1
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 130-15AST Battery Replacement: 2 단계, 이미지 2/2
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Battery Replacement: 3 단계, 이미지 1/1
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Before proceeding, make sure the computer is turned off and it is not connected to any power source.
    • Using a Phillips #00 screwdriver, remove twelve of the 6.0mm screws.
  5. Lenovo IdeaPad 130-15AST Battery Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad 130-15AST Battery Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad 130-15AST Battery Replacement: 5 단계, 이미지 3/3
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Battery Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad 130-15AST Battery Replacement: 6 단계, 이미지 2/2
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up.
  7. Lenovo IdeaPad 130-15AST Battery Replacement: 7 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove three 6.0mm screws.
  8. Lenovo IdeaPad 130-15AST Battery Replacement: 8 단계, 이미지 1/3 Lenovo IdeaPad 130-15AST Battery Replacement: 8 단계, 이미지 2/3 Lenovo IdeaPad 130-15AST Battery Replacement: 8 단계, 이미지 3/3
    • Using a pair of tweezers, remove the black plug which includes 8 wires.
  9. Lenovo IdeaPad 130-15AST Battery Replacement: 9 단계, 이미지 1/2 Lenovo IdeaPad 130-15AST Battery Replacement: 9 단계, 이미지 2/2
    • Grabbing the sides of the battery with one hand, remove the battery from the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Trever Resheske
회원 가입일: 09/22/19
768 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 7,561
